The wings were temp installed using 2 pins in each main spar. The 20 bolts, 10 on each side, are very tight fitting bolts and have a pattern for correct install. The big bolts required the rivet gun on low low setting to gently tap into place. All bolts went in good with no problems. Wings are now in place.
